name='llwyd' said:straw + lungs + goggles is cheaper again
name='Doddsy said:llwyd' said:straw + lungs + goggles is cheaper again
You should video that next time you're cleaning your pc and post it up!
I generally use compressed air and a vacuum cleaner.
name='Doddsy' said:You hold the vacuum away from the comp catching the dust. And a vacuum is also the recommended way to clean an arctic silencer (I have one on my vid card).
FragTek said:Wirelessly posted (LG Fusic: Opera/8.01 (J2ME/MIDP; Opera Mini/2.0.4719/1528; en; U; ssr))
k good because we should all know what happens when u clean to close to the pcb with a vac.
Yep been there done that, except I use a soft to medium toothbrush. Simply throw mobo into the sink and scrub away...just make sure it's bone dry before connecting againname='Rastalovich' said:Washing-up liquid, a brillo-pad and a scrubbing brush.
name='deathwish' said:canned compressed air
anti static brushes
Hoover to suck up the dust you have brushed off
