Hiya guys
Wasn't sure where to put this thread.
But i'm wanting to water cool my x850xt. I will hopefully be getting my Mach back soon from denmark. So all i need it to cool is a GPU. (x850xt fans are doing my head in)
I was thinking of getting a single rad and fitting it to the top of my lian li p-65 case. Probablt move my optical drives down abit so it can fit close to the front of the case.
As for pump. Think a small one will be good enough. hidden at the bottem like someone did on here recently.
Not sure about a rad. Maybe a 3.5 floppy one. Then all thats left is a block.
So if you could give me any ideas that would be cool.
My card can do 567/620 on air. Get lock ups after that. So need to volt mod i think. Temps on air were good never going above 60°C at full load. So think there would be some head room for a volt mod on air. But if i can cooling well with water then so much the better.
Its either that or get a whater chiller from fatty and make a case for it and then stick it on the top of my case!!
Hope you can help
Smokie
Hope you can help
Smokie
