Phil Stanbridge
I'm hopefully getting some OCZ 3200 Platinum which I've heard is excellent with A64 based systems - at the moment I'm using OCZ 4200 EL DDR which is great at 1:1 with Intel based systems but it's overkill for the A64. What memory do you guys use with your AMD setups?
