paulstung New member Jul 10, 2013 #1 As above really after upgrading to Haswell I have everything here for a back up rig, all apart for the gpu. So what would be the best bang for your buck, for under a ton ?
Feronix New member Jul 10, 2013 #2 HD7770/7790 I would think. Unless you can find a GTX 650 Ti boost for that price.
I iBeInspire New member Jul 10, 2013 #3 Some 650 ti 1gb's come in around £105 at times, so one of those would probably be worth it If not, 7790
M Mathius New member Jul 10, 2013 #4 http://www.aria.co.uk/SuperSpecials...1210-00-20G]+++4+FREE+GAMES!+?productId=56395 £108 Only noticed this today, thanks to Aria_RawZ If budget is strict Ebuyer 7790
Netroxen New member Jul 13, 2013 #5 My granny, she's old and weak but her brain still works... Just need some splitter cables and you're good to go. Do I hear a £90 somewhere...? Jokes aside, a GTX 650 Ti could be a worthy purchase. It won't crunch frames like its bigger brothers but it'll deffo pump some reasonable frames out. Example: http://www.aria.co.uk/Products/Comp...R5+PCI-Express+Graphics+Card+?productId=53310 +£22 unfortunately
vorticalbox New member Jul 13, 2013 #6 7770 aria net is £81 on aria or you can get the asus 7770 1 GB for £92 from amazon. my friend brought a aria net card and got sent a xfx card. i have the asus 7770 1gb is a nice card for the price.
