Best GPU for around $300
Rarazuh
Hey guys, I'm building a new PC very soon and I'm still stuck on what GPU I should get for performance, price, and upgradability.
I'm looking at atm:
MSI Twin FrozR III R6950
EVGA 570
Any other alternatives either reference or nonreference that would outperform for a better or the same price?
Please comment. Thanks.
Even though I have an 6970, I'll give this a +1, Buy the 570 Lots less noise and heat for the same performance. (If your leaving it stock that is). Also be mindful those coolers on those 2 cards will be putting all the heat in your case. So make sure you have good air flow.
I'm looking at atm:
EVGA 570
Well Chuck, you should look at Tom's Hardware site. Its best for price/power comparison.
Best Graphics Cards For The Money: April 2011
Best PCIe Card: $200 To $300
Best PCIe Card: $300 To $400
Graphics Card Hierarchy Chart
It won't tell you the make but will give you an idea which chipset is best. Hope it helps
I would go with the gigabyte cause of their way of cooling the chip and board...
They keep the card cooler than many of the other coolers, well from what i have seen.
