I see, I have pretty decent speakers (Acoustic Energy Aego M) but I'm assuming by the general usage you're implying are like music production etc to use for sound cards? How is it that a lot of people who use their PCs have sound cards for gaming purposes?
Thanks for answering CocaCola.![]()
well if you have a good sound card such as the stx or st then of course your going to get much better sound but coca cola is right you have to have some decent speakers for anything to sound. for example I bought my z5500s in which I thought sounded pretty amazing for 5+ year old speakers, However when I paired it the my stx the sound was on another planet. I would defiantly recommend anyone who wants better sound to get one![]()
Yeah I'm quite the audiophile...so I love to have my sound quality at it's best. Think I may have a little look around on these.![]()
A dedicated sound card for starters will relieve stress from the CPU, on board audio uses more CPU than a dedicated card does.
Now time for the tech stuff. On board audio almost ALWAYS has a 16bit 96,000hz peak, which is just above the 16bit 48,000hz which is DVD quality. Most Creative sound blasters have a max of a 24bit 96,000hz which is a larger bandwidth, thus better audio but not a larger range than 16bit 96,000hz. A sound card such as a Xonar DX will do 24bit 192,000hz which is as high as you can go, which is the same bandwidth of the 24bit 96,000 but has a larger range for creating more realistic sounds. The larger range means you can reproduce more sounds. BUT a good sound card is deprived without a good sound system.
Awesome, thanks guys! and yeah I did read that Creative had really bad issues with sound drivers. As it'll be my first sound card, I don't need anything too expensive.
The house I live in isn't exactly made of stone and lined in soundproofingso I don't want to have the neighbours knocking at my door to keep it down. Anything good sub £100?![]()
Xonar DX by ASUS.
