Belkin routers-N150 "F7D1401zb" or "F9J1004zb"
minus47
Sorry for the long description.
1. Which one of the aforementioned routers is better?
2. I RMA'ed the former and Belkin gave me the latter. The former had a vertical form factor and internal antenna but the new latter one has a flat form factor and external antenna. The old one had a 3-year warranty. This new one has a 2-year warranty. Also this new F9J1004zb is about 2-8 dollars cheaper than the old router.
3. I contacted Belkin and they said that a new F7D1401ZB was not in stock which is why they sent the latter. But they did have 1 demo "F7D1401zb"(not new, opened and used) which they said they would send(if I really wanted it) in exchange for the new F9J1004zb router which I have right now.
The problem is that they insisted I not open the packaging of the new F9J1004zb if I want to exchange it for that "not new, opened and used" demo F7D1401zb router. Since I can't open the packaging, I can't know how well this new router performs against the old one.
Should I exchange this new F9J1004zb for the old demo F7D1401zb or should I keep the new one?
I want to know which router has more features since they perform about the same(I think? because they're both N150)
