Hi Guys,
The heaven benchmark score was 1866 for the person who asked.
I could easily OC further, My max stable OC with stock volts that I had time to test was:
Core: 1192Mhz
Mem: 1672Mhz
WAS TESTED OVER ~12HOUR RUN
Could probably push it further, but once I got to 1300Mhz one the core I needed more voltage for it to render properly. The voltage was not altered in any way at all. Also I noticed the max temp increased to around 44-46C if I had the loop push the freshly cooled water into my CPU first, which is still quite good. Then again I spent around $500 on this cooling loop, so this performance is MANDATORY
I should also note that the EK backplate looks great, Probably one of the few that I would like using, The nice glossy finish and plain appearance is the only reason I even bothered to get it, as I really do not like those backplates with all those holes and cutouts just to make it stand out.
This is my current loop order Pump>res>Gpu block>GTX 420 rad>CPU block>RX240>origination point. Over all this is working out quite well for me, as the RX 240 fans are also doubling as a source of intake, so the cooler air helps the top 420 rad.
Also I got the elpidia branded memory on my graphics card instead of Hynix...
Anyone know if there is much of a difference? As I have honestly never heard of elpidia before, however apparently they are very widely used and one of the worlds largest memory manufacturers, however they recently got bought out by MicroTech.
Well so far I am more or less happy with the card, considering I generally have it clocked to 750Mhz core and 900Mhz mem to reduce power usage and heat (not that it matters anymore
) when I do not require it full processing power.
Here are snapshots of both my daily/normal usage clocks and the other the OC, Could probably OC a little higher.
https://www.dropbox.com/s/0md2f3cs2hpw4xd/Untitled.png ~8hour run
https://www.dropbox.com/s/mi213ocuuwjvwv8/OC.png ~12 hour run
Unfortunately I had to resize the images, as there were limitations to the documents that I could attach. If you would like the full size and original image, just send me the email address you would like me to send it to.
Also note that the Untitled run was with an ambient of around 26C and the OC run was with an ambient of around 28C. I tried to take a photo along with the thermostat at the time I ran the test, however this photos wouldnt come out right.
