Hi,
Was looking and hoping someone could offer me some advice please?
I'm going to be rebuilding a new rig and want to start and tidy things up a little.
Previously I've used Barbs only. I want to give compression fittings a try.
Having not seen one up close and personal before to be able to try one out I wanted
to ensure I was making a good choice by converting to using them where presentation is key.
I would be using compression fittings on the CPU block and also the GPU block.
Are these Compression fittings safe?
I know you have to screw them in to give the tight seal. Are they more risky to use then a barb?
Any recommendations to good quality ones that could make installing them on the likes of a CPU block
more easier? (for example screwing the compression cap).
Here is another question.
45 Degree angling... I've seen tom logan use what seems to be a complete 45 degree angle with a barb end so you can just
clamp the hose on. Do these exist like that or was it just how it looked? They was in black and he used them on the
CKC - Complete - Coolermaster Koolance Cosmos video for the bottom 240 rads.
Any recommendations to what I can use for 45 degree fittings like those as well please?
Thanks
Thanks
