ATI 6950 QUESTION???
adman101
I am looking to get an ATI sapphire 6950 for christmas and want to know if it will work with my current system
processer: AMD Athlon II x4 630 Propus
Mobo: Gigabyte GA-MA790GPT-UD3H PCI 2.0, (believe its a late 09 make)
RAM: Patriot "G" series 4GB
OS: Windows 7 32 bit
EVERYTHING IS NOT OVERCLOCKED
As long as you have the required PCIE power connectors for the card and it fits in your case I can't see why not.
thanx for your reply I looked on dimensions and i might have to go to the 6870 intead of the 6950 ( it save an extra inch) I do have the required power connectors 2x6pin. THANX THOUGH
