Athlon 5350 igpu overclocking help
Nathlm
I have the igpu overclocked at 780mhz core from 600mhz and 950mhz on the memory from 800mhz, however afterburner won't allow me to go any higher on the core no matter what settings I change in the afterburner menu. Is there a way to take off the 780mhz cap on afterburner?
I'm sure we will see a version with higher limits in the future, hopefully.
I'd really like to see benchmarks of stock and overclock results on these chips. I think these AM1 CPUs have some really good potential usage senarios that people need to explore.
I can do whatever benchmarks you want just make a list and I'll go through them in either this thread or another
edit: from what I have seen in league of legends the difference between 600 -> 780mhz is quite significant haven't done averages but seems to be about 20fps (on low-medium settings)
Have you managed any overclocks on the CPU core?
yeah got it to 2.415ghz with 1840mhz RAM haven't really messed with ram timings yet though
these probably aren't final clocks they are just what I was happy to get, I don't want to push it much further due to only having the stock heatsink on it
Edit: on a side note the cpu is the cutest little thing I have ever seen
