Asus RAID5 Onboard Fail
H3M4NZ
Ok, I will start this thread by stating that I know I'm a bit of a dipshit, creating a RAID5 array with an onboard controller.
So, about 2 weeks ago, I created my first ever RAID5 array with 4 4TB seagate drives, on my home plex server. Worked perfectly for 2 weeks, until (I think Thursday this week) when I woke up one morning to see Intel Rapid Storage Technologies "app" telling me that my RAID was "degraded" I thought it odd that one of my 4 brand new drives had failed in the first 2 weeks of operation, but removed the offending drive and tested it in my main rig with a usb>sata Startech caddy. Tested fine (I didnt format the drive, however it did show up in disk management and crystal disk info) So presume it is fine.
I put it back in the server, booted back up (note, I didn't boot up without the offending drive), and the IRST now showed the RAID as failed - correct me if I am wrong but RAID 5 should be able to cope with a single disk failure. I tried booting up without the "failed" drive and still shows as failed. I used a "RAID Recovery" freeware tool to try and recover the RAID, but that has literally just failed after about 34hours.
I am now stuck and wondered if any of you wonderful people have had a similar experience / could recommend a solution / tell me I'm a tight arse and should have bought a dedicated RAID card. I have 6.5TB of films and TV and other stuff currently in the balance of life and death and if anyone could solve this I would be eternally grateful, and even offer to drive to where you live and give you a kiss :)
Anyway, cheers in advance for the help/insults.
Ben
You need to look at rebuilding the array if it is telling you that it has failed. There are numerous reasons as to what could of caused this, but you first need to try and rebuild the array using the Intel Matrix tools that are installed with the controller software in Windows.
If you still get issues, you might want to have a look at Spinrite software, available from https://www.grc.com/sr/spinrite.htm
Hope this helps.
