So have a PG248 swift monitor that work perfectly normal when running it at 144hz but when I overclock it to anything above 144hz it goes black randomly for one second and then the image comes back up. So I am wondering if the problem would be a bad displayport cable, the Amd r9 290 I am using or the monitor.
The monitor is made to overclock with Geforce cards only and I don't posses one myself so I can't test if that's the problem or not.
The displayport cable I used was the cable that came with the screen.
Would be thankful if anyone knows my problem or could help me identify it.
Thanks in advance!
Thanks in advance!
