Asus P5KPL-AM/PS
zak4994
Do NOT read the writing in small unless I tell you to as this was the previous problem.
So my cousin bought a new case which came with a PSU, a coolermaster extreme power plus 460, and we found that the old motherboard didnt work with it.
So we bought a P5KPL-AM/PS motherboard, hooked up everything including the VGA cable. We turned it on and found that nothing appears on on the screen.
What could be wrong guys?
Edit: CPU fan doesn't work now.
Connected the 4pin wire.
Specs:
E6600
1GB RAM (2x512mb 533Mhz ddr2)
Graphics=Onboard (motherboard)
Sound=Onboard
Anything I'm missing?
That problem is now fixed.
But I have another problem.
Windows doesn't load.
It goes through POST and then it just stops and there is a cursor/underscore constantly flashing.
Normally you would get a progress bar like this:
but instead of that you get the flashing underscore.
I'll see if I can get a vid up.
name='PeterStoba' said:
How didn't the new PSU work with the old mobo?
The old mobo was an Asus Ipilp AR.
and the 20/24 pin connector, at the top in black, was smaller than the standard 20/24pin connector port.
Fixed it.
Found out that the motherboard doesnt like his processor. Works with a celeron D but not with his current processor.
So current problems are that core 2 duo does not work with the mobo.
DAMMIT!!
Now for some reason windows doesn't load.
It goes through POST and then it just stops and there is a cursor/flashing underscore just constantly flashing.
That's where boot0 is initiated but doesn't continue.
It can be one of 2 things, either ur mbr is messed up which u can fix with the install dvd and diskpart, or ur sata settings are on AHCI and ur install doesn't like it. (theres is an outside 3rd where a dskchk needs to be used to correct some filesystem problems - this is usually when u get to the screen in ur op and it either freezes or recycle-boots)
I'd go with the mbr.
put in the windows cd,boot from it and go into recovery mode,then type fixmbr and press enter,iirc
Guys I fixed the problem.
I had re-installed windows and it worked.
Reps will go to both Nepas and Rasta as they provided me with the most information.
Cheers guys.
Close thread. :)
