Asus EZ flash 2
Loraboy
Het there Guys!
I was about to Update my Asus P5N73-AM BIOS with the famous Asus EZ flash 2
So, i went into a problem... The screen...
I do only see the half Of mys screen., so the right side Of the screen is blank. And a half page is on left side..
Is it the resolution?
Bad Computer?
It's making me sickness and tired.. The bios is like from 2006 or something..
Kindly Regards
iLoveOC3D
mm i've had that problem with some BIOS'es, although not as extreme as half a screen gone.
have you tried the auto function on your monitor? or just a simple placement on the screen?
I don't remember any problem with my Asus P5B board (on a Samsung 206BW monitor).
Het there Guys!
Bad Computer?
Kindly Regards
iLoveOC3D
Have you tried using the Phoenix Award BIOS flash tool version 1.33 from the download section for you mobo at the Assus website?
Look under BIOS-Utilities
http://uk.asus.com/p...C4H82eOmIEKdVAs
