Has anyone got a mach2 to hold reset on the asus a8v or is everyone using a seperate psu to power the mach2? .I have tried the latest firmware but the same problem occurs - mach2 powers up but does not boot the pc.
I think that it may be an issue with your firmware! Someone else will probably back me up! There is a software section on the site, that you can get it from!
Do not use this firmware unless you have start-up problems with the AMD 64 / FX compatible motherboards.
Instructions:
1. Save the file to the harddisk.
2. Unzip the the file using a standard decompression tool found here.
3. Start the BOOTLOAD.EXE program. Default Prometeia software installation folder is: "Program Files\Chip-con\Prometeia". Point to the decompressed STE file and start the firmware upload procedure.
