do it the same as you would with a CPU,up the clocks then when you hit apply if it hangs or you get that little yellow triangle in the taskbar (uasualy after a hang) then add more volts,but keep your clocks the same
just keep going like that,if you can play a game fine (intensive one) then it should be ok.
as far as icrements go voltage just bump it by 1 slide,i usauly bump the core,mem by 5mhz but you could use 10mhz
ATI tool is a good tester but its not without its flaws.
also when do the artifacts show I.E after 30secs or 5 min?,a good thing to notice when playing with clocks is how many artficats you see or how many its counts up,as the less you see the more stable you are getting,yes you should see no artifacts but only run it for about 15-30min.
and what are your temps and fan speed,try wacking the fan to 100% and see if you get artifacts then
