name='Diablo' said:You haven't got any other asus software (smart doctor etc.) running?
name='Diablo' said:Does it only BSOD with the Ares?
name='tinytomlogan' said:Should not have installed smart doc, thats where the problem lies it corrupts the driver. Thats why I told you to JUST install the driver on the disc nothing else. Otherwise I think you are going to have to return them mate and just use simpler cards as this may be a bit too advanced for you.
name='Diablo' said:Yes, the cards can control their fan speed without the software. Smart doctor is basically an overclocking tool, and can cause untold amounts of grief.
name='Diablo' said:I wouldn't. firstly it isn't ares specific, secondly, I've just lost my crossfire option.
name='UltimateTK' said:ccc 10.7 does not work with ARES...damn..have to wait until Asus release new driver.
name='tinytomlogan' said:The normal driver works... I have told you 3 or 4 times CCC doesnt work.
I hate to be harsh dude but if you had followed our advice it would be working already.
name='Br1t1shB33f' said:UltimateTK
As Tom has said multiple times.
DONT USE 3rd party Drivers ( Catalyst Control Centre is BAD )
use ONLY the "Display Driver" on the disk with out any other software installs from ASUS/ATI.
It would be best to do this from a Fresh install of windwos as u have corrupted ur driver set.
So....
1. Reinstall windows.
2. Install the "Display Driver Only" off the disk supplied with ARES
3. Crossfire "will not" work
name='tinytomlogan' said:We got there in the end. If you followed the advice from the start youd have had it sorted alot sooner fella.
The Ares disc should auto install the drivers for you, but DO NOT install any Catalyst programs from the ATI website (yet) and dont install any of the Asus programs on the disc. Also keep that 2nd GPU out of the system.
Id also say tbh send the 2nd one back as CF does not work, and I cant see that changing very soon dude. 4 gpu's never work that well together so spend the money on a 980x or something!
name='tinytomlogan' said:Id also say tbh send the 2nd one back as CF does not work, and I cant see that changing very soon dude. 4 gpu's never work that well together so spend the money on a 980x or something!
