Arctic Cooling Freezer 7 Pro and dumb move of the day
So... in a rush to get the new computer together over the Christmas break... sure enough I failed to read the instructions
So... thinking the bent fins at the bottom of the Freezer 7 should be aimed down towards the Northbridge (?)... applied the paste, tightened 'er down... and voila... seemed to work good.
SpeedFan CPU report:
Temp 1 34degrees
Temp 2 27degrees
Then... after all was together... realized that the fan is competing with the PSU intake... dang... should be pushing towards the back of the case instead.
pic from FrozenCPU
So... reason for posting this dumb move... ha... so other newbs like me can see how not to do things
... and the build continues....
Temp 1 34degrees
Temp 2 27degrees
pic from FrozenCPU
