arctic cooling freezer 7 - marks on copper?
name='Toxteth O'Grady' said:
Give your local Trading Standards a call. They're the legal experts.
:cool:
p.s. lapping is real easy. Give it a go - you'd be surprised.
:cool:
TOG
i'll give lapping a miss :haha:
all i want is a cooler that will keep my chip cool, and if this will do the job then sod what it looks like, i wont see that bit
you guys think it will be safe then?
cheers
If it's flat and only discolored then, yes. Especially with AS5. All copper heatsinks, even highly-polished, mirror finished ones, discolor over time during use.
:cool:
TOG
:cool:
TOG
its the during use thats the problem, its brand spanking new, or supposed to be lol ( but i get your meaning)
everything else is spanking new..
it feels the same as the rest of the surface, i will be giving it ago when i get my AS5 (that will be fun doing it, never used it before)
currently enjoying the banter from the seller atm about how poor his customer service is
I think you can send anything back within 7days of recieving it, whether it's faulty or not as part of the distance selling act.
http://www.oft.gov.uk/NR/rdonlyres/1E6F3C94-8BB0-4374-A65B-6281E030C3C9/0/oft698.pdf
If you offer a replacement for faulty goods that have been returned
by the consumer, the cancellation rights under the DSRs will run for
seven working days from the day after the day the consumer
receives the replacement goods, provided you have previously
complied with the information giving provisions in the DSRs
Ok I know this is off topic, but please oh please use OC3D uploads.... People that use ImageShack when there are so many better, MUCH FASTER, ad-free options it makes me want to go friggin postal.
If I don't use OC3D I use photobucket.. Seems speedy enought! ;)
Sorry for off topic! :wavey:
Agreed tbh.
Hi guys!
fitted the arctic freezer 7 pro with some AS5
been running for the past hour, with the nice and noisy fan running at full blast (for the time being)
reading from TAT (IDLE)
core0 - 42
core1 - 41
or there abouts ^
nothing is overclocked, seems to be a few degrees lower than the stock cooler so far, will see how it goes over the break in period
Doesn't seem that bad, TAT readings are quite high.
Altho if it's not overclocked etc I guess it's not brilliant.
it's idle guys
having tried load yet, want to break it in slowly
or shall i hit load?
i am pretty sure it is on right, the paste was done right as per arctics guide.
nothing is overclocked and fan is running full speed
core temp shows
40
41
i dunno mine is oced to 3.3 ghz and vcore is 1.475 and it idles at 40 and bfore ocing it idled at 35 so idunno what is your problem , i have the same as you but i left stock paste and added some akase paste cause i smeared a bit around what rpm is the fan accordin to the uguru the max of the fan which min is 2880 rpm tell us urs
my fan speed is
2860 rpm or there abouts
running orthos now, currently on 51 will no doubt rise
how long should i do it for
name='techmob' said:
my fan speed is
that should be it well i dunno maybe the case is hot ? try to touch the heatsink see if it is warm? then try on load and see if there is a difference on the heatsink
i ran orthus for 20 mins
and it was steady at
54
53
hottest one core got was 55, but it flickered to 54 mostly
what is the default vcore for the e6600, my motherboard asus p5w is set to auto, and it shows it as
vcore 1.23
cheers
