Anyone recommend which bundle to get ?
Zomgitzgrinch
Hi
So atm I have a 8370fx with a ASUs oldish mb wanting to upgrade to something a bit more stable not looking to spend over like £900 for something, but I don’t really play games that require ultra graphics I use my PS4 pro for most games I like to play some games on my pc like planet coaster, I also use Sony Vegas to edit things for youtube can someone recommend a good upgrade that’s going be suitable and not put a hole in my pocket.
https://www.overclockers.co.uk/pc-components/upgrade-bundles/amd-overclocked
Thanks.
My case and psu are good got the cooler master h500 mesh and Seasonic SS-620GM2 M12II-EVO 620W (80+Bronze, ATX 12V) PSU/Power Supply
That bundle should do you fine then man. I would wait on GPU to see what happens over the next month, then make a decision.
