mr_fishbulb
I read in Dav0s' sticky that it's ok to use faster ram than your FSB as the RAM will slow down.
Is it ok to mix sticks of different speeds?
My system has FSB of 133 and it already has 1 DDR-SDRAM of 512meg at 133Mhz. Will it be a problem if I put in, say, PC3200 RAM as it's cheaper than the PC2100?
Also, this is the bit I am most confused with - are all 184-pin DDR modules for fitting singular? Or must some be fitted in pairs?
Cheers all
Cheers all
