Mgutierrez33
How loud are those Spectre Pro's you're using? Was thinking about using one to replace the stock front fan on my 600T. Also what's the airflow like on them... I have a hard time believing over 100 CFM.
I love the idea of the top mount fan controller, nice work on that mate. The front looks like a Cylon with those red LEDs going around it :lol:.
most of the noise that comes from them is the air moving . This is with them not being properly mounted without rubber noise dampeners but,mind you the first case im coming from before having this one was a thermaltake armor vhb6000 or something like that which had a 240mm fan on the side of it that was horribly loud, so to me this thing is whisper quiet i would put the fans on par noise wise with the stock ones maybe a couple decibles louder for an increase in performance.. If you use the 7v adapter they are almost not audible .
Good... GOOD... this pleases me, all goes according to pran >.>
The fan controller does look awesome there. One question though. Since the reset and power switch are part of the i/o panel which includes the fan controller, how are you now turning on your system??
my super top secret reservoir
Are you even allowed to talk about super top secret reservoirs? Do you have proper security
clearance?h34r: :lol:
That is one special reservoir! I wonder what it would look like with white (bone) or black coolant? Excellent idea.
