I'm feeling like I might have another play with the cables and the LED placement.
Not satisfied yet brother?
Yeah tell me about it. I stopper working on those cables cause I don't have many options as they're short. but if they weren't I'd probably still be working on them till today. :lol:
go for it mate!!!I'm feeling like I might have another play with the cables and the LED placement.
sounds promising... i'm waitingi found a way to hide that single led that was in view without having the re route it from the routing i wanted. i have some pictures i will post them soon. plus i did a few other small things as well.
Hi Andre,
Have recently started following your Z77 build. Looks great btw. Very impressed by your cable management and the overall look you have achieved inside the case.
A few questions if you have some time to respond. Where in TO do you find those tie mounts you use for your addtional cable management? Also have you found a store in TO that sells those H-Frames? Like your case selections too (although a few seem a little pricey). Thanks for your help in advance.
Hey thanks for your quick response. Going to grab some of those mounts asap. Your interior has motivated me to do some improvements. Hardware should be listed in sig below. Just waiting to see what happens with new AMD 8000 and Nvidia 700 series. No real practical need to updgrade at the moment (used primarily for strategy gaming) but lots of fun to evaluate, decide and then make the changes. Just getting caught up with your latest updates - like the LEDs - have been considering doing something similar but never found the right product - or clean way to install. How do you like the new memory? Very happy with my Kingston Hyper X - but am just running it stock at 1600 - never any issues
Thanks for LED info. Agree with your preference of obtaining a nice "glow" - and not overpowering with bright lights. Have a blue theme right now (from a blue LED case fan) so may look at the blue you mentioned just for a small addition. Still getting caught up on your latest iterations - you do a nice job with both the work and in capturing what you have done. I see you have moved the drive bay back to the front - like it both ways but maybe just a little cleaner with the way you have it now - but really it looks great both ways. Have a non modular PSU here (didnt realize the big benefit of modular when I got it) so I have a little more of a cable mgmt challenge with some of the extra cables. Its not too bad right now but not even close to how clean yours looks - will try to post some pics for a before and after once I get some of those mounts and can find some time to do some work. Like how you have done the 6/8 pin GPU cables and am going to see if I have that extra hole on my PCB for my Twin Frozr. I notice you get the cables nice and tight - I am always a little concerned about things maybe being a little too tight - and maybe pulling or pinching something too much. Any advice in this area? Notice you have a little twist in some of your cables too where they attach - any advice? Once again many thanks for your posts, pictures and responses to my inquiries. Much appreciated.
Hi Andre , Nice job on the LED's and the cabling. The led's are much better and show your system very well now .
Have you decided which case you want next? , I have to agree with you on the Lian Li cases , they are very nice. One of the things I like is , most of their cases have a card reader.
I keep looking at the Caselabs Merlin sm5 or sm8 , I really like the Magnum m8 but I'd have to find someplace to put it , it's huge.
But the options are endless with Caselabs cases.
Seen this already. I think it's very interesting, looks better, the temps seemed pretty low, it seemed pretty quiet, the pump looks massive and I like that alot, the black shiny hoses are brilliant... if I was to build myself a custom loop I'd use black shiny hoses instead of the so overrated transparent tubing everyone uses. And!! you can customize it, add water blocks to your graphics cards... this one looks promissing. What do you think?
