Shift87
So I am having a bit of a problem with HWMonitor and wanted to see if anyone could lend a hand. Yesterday I started OCing my 1100T got it to 3.8ghz everything was fine would boot into windows, prime95 ran for 4 hours and benchmark said no errors. Got to 4ghz everything was fine prime95 showed afew errors so i bumped the voltage up 1.475v from 1.45v load up prime, run the benchmark everything checks out, I start to run a blend test open up HWMonitor and get this:
No temps on any of the cores? and at the same time im noticing that the CPU fan is cycling up and down rpm going from around 900 to 1400ish every few seconds. I lowered the voltage down to 1.45 and the CPU fan returned to normal but still no temps on the cores. Brought it back up to 1.475 and the fan seems to be alight not sure what caused it before.
At 4.0ghz and 1.475 volts I took a chance and ran a blend test for 20 hours and everything checked out so I know its stable. But why no temps once the voltage was changed?
Any input would be appreciated
