PBaines New member Sep 30, 2011 #1 Hello all ! i just bought my new AMD Phenom CPU 980, and when i go to core temp it only shows 3 cores ! and cpu-z, have tried other bios's and programmes, also tried core unlocking
KING_OF_SAND New member Sep 30, 2011 #2 If core unlocking didn't work that usually means one of your cores is broken. I would try another motherboard to test it.
D Diablo Active member Sep 30, 2011 #3 Check the bottom of the CPU for bent pins. If only three are showing up, it may be RMA time I'm afraid.
