Alphacool Screws + Corsair SP120
coalminer071
I was just wondering cause most of you who used alphacool screws know their head is quite small in diameter. Should i put a washer on it? or it should be fine without it
They're so cheap you might as well just get a pack of washers, then you don't have to worry about it either way.
