Air 540 with dual 280mm rads in push pull
Davva2004
Active member
Hi all,
Could anyone confirm if it's possible to mount two 280mm radiators in the Air 540 in push/pull? I'm certain a 60mm can mount at the front in push/pull if the outer fans are fitted outside the chassis behind the outer mesh, but I'm unsure about the top. Does anyone have a definite top clearance figure when using a 280mm radiator?
Cheers all!
