AIO Cooler pull-only: SP or CFM fans?
sosolidshoe
So I intend to grab an H100i or Kraken X60(if they ever release the bleedin' thing), ideally the latter given that I'd prefer to use less fans(Noctua's make my wallet cry) than more and it seems to give a better noise to performance ratio than the H100i, but I'm not sure on the fans.
I've never owned anything other than mid-range air coolers in the past, so my knowledge in this area is limited to what I can find, but this is a question I couldn't find any info on. When you're using two fans on a radiator in pull configuration, are you better off with SP-optimised fans, or fans with the highest CFM?
