A8V Deluxe/ Mach2 problem
Psilonaught
this evening i did the Alt + F2 trick and now have a working A8V/ Wincester combo but i can't get my Mach 2 to play ball with this mobo.
Basically the unit powers up fine, but when -33c (power on temp) but the mobo doesn't power on. BUT, as soon as the LCD says "powering down" the mobo starts but then shuts down again once the Mach2 turns off
I have the grey/white cable from the case's power on switch connected to the blue/white Mach2 cable, and the yellow cable from th MAch2 is connected to the power on pins on the mobo
can anyone help?
