Making an attractive Threadripper system with AMD/Cooler Master's Wraith Ripper
Wraith Ripper PCIe Issue - GPU case mod - fix
Whats the performance hit when using that pci-e riser ?
I have around 5-10% hit using my Thermaltake premium riser 200mm...
I didn't realise there was a performance loss when using riser.
The performance loss comes from the card being too close to the side panel and therefore heat gets trapped and therefore lowers clocks.
If you get it further away from the side panel it'll be fine
Ahh, so you are saying that it is Nvidia boosting their GPU less due to decreased airflow and higher temps?
That is a big problem for cases with native vertical mounts. very close to windows, especially for cards that are more than two slots thick.
I'm surprised you didn't know this? That's why we had those vertical GPU solutions come out during Computex earlier this year. It was to avoid the thermal issue
I was clarifying, in your earlier post, I thought you were referring to losses from the cable itself and was thinking that 5-10% was super high for what should be a premium cable. 1ish % should be as high as it gets outside of cheapo risers.
My post started with "Ahh", as in "Ahh, now the 5-10% now makes sense" kinda way. Or at least that was how it went down in my head. Lol.
At least the next person on this thread will know exactly where the performance loss comes from. A good PCIe riser cable has a negligible performance impact, nobody noticed a 1% difference.
I got a waterblock on mine and temp never goes over 50c, and there is definitely a performance drop benching this card with timespy extreme, 4850'ish with the riser and 4999ish in the pci-e slot, tested multiple times.
I thought it was meant that there's a decrease in performance as a result of the riser cable, not the space restrictions.
I don't see how you could get confused when I never mentioned the cable I just talked about heat, space restrictions, lower boost clocks? I don't see how I could have been more clear
But yes riser cables are fine so long as they aren't cheap. I would love to use one in my ITX case but not sure if it would mess with airflow for such a small case
My confusion came from FTLN's original post, not one of yours![]()
There isn't, unless you do something wrong or the riser is absolutely crap.
