WYP News Guru Sep 4, 2022 #1 A highly versatile GPU mount that comes with an included PCIe 4.0 riser card. Read more about Cooler Master's Vertical Graphics Card Holder Kit V3.
S smilertoo New member Sep 4, 2022 #2 only half done Screw showing it off, add a shroud with a 140mm fan mount so we can pump ALL the gpu heat out the back of the case, making CPU cooling so much easier.
AngryGoldfish Old N Gold Sep 8, 2022 #3 smilertoo said: Screw showing it off, add a shroud with a 140mm fan mount so we can pump ALL the gpu heat out the back of the case, making CPU cooling so much easier. Click to expand... Has that actually been tested as a viable solution? What seems logical doesn't always translate to better thermals in reality.
