800d or etc. case for watercooling
Landopops
Hey people
I were just wondering what cases you would recommend for watercooling.
Im planing a triple radiator for my cpu to start of with and then put on a double radiator and a gpu block.
Hopes for the best
Jacob
I know Tom isn't a huge fan of the 800D as there are better cases out there for watercooling in the same price mark so for starters my guess would be that is a case to avoid.
aside from that my watercooling knowledge is none to very limited so I will allow someone far more qualified than myself to recommend an alternative
I have just searched a bit on the internet and the nzxt switch 810 gunmetal looks pretty beast
But is it any good?
The 810 is good, and you can easy get a 360 rad in top and 240 rad i the buttom or front.
So That is just up to you ;)
Check out the review by TTL on the Switch 810 - LOT of good information in there. Also, he has a bunch of other case reviews where he will always discuss water cooling capabilties.
Other cases to "consider", Bitfenix Shinobi XL, HAF X, some of the ones from SilverStone, etc...
My current rig (first watercooled one) is in an 810. It really makes watercooling easy. Don't even bother with the HAF X, it's just outdated.
