On the 680i lt there is a heatsink and fan next tot he CPU and near the GPU slot is a second fan with no heatsink.
I want to put heatsinks on both.
Which one is notherbridge cooler? Only single slot cards fit in the PCI-E slot if theres a big heatsink there, so I was wondering about this:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-044-TR&groupid=701&catid=57&subcat=399
Seems it would work, so if that did fit in that one, what do i get to fit the other one?
Will this one do?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-045-TR&groupid=701&catid=57&subcat=399
Just wish to know because I'm selling my 7950gx2, hopefully to get a 8800gt however if its performance isn't above that of the 8800gts, I'm purchasing a 2900pro 1gb and clocking it up to over XT speeds.
Will this one do?
