Msi z87m not botting properly
jaslarziv
Ok guys i build my rig about 2 months ago and i jus install a gpu to it about 1 month ago, yesterdey i was playing tombraider and the pc just restarted out of no were now everytime i turn on my pc the screen goes black like it get no signal for about 2 minutes after the win logo and then goes to desktop any help with this please i dont know wat to do also in motherboard i get code A0
ok have you tried re-installing the nvidia drivers? what card did you have before?
Yes i try installing nvida driver again and i dint had a gpu before this is my frirst pc that i build.
I think it might be a problem with the intel hd because when i try to open the hd utility tool it just close by it self and when i rebot my pc in safe mode it boot up normally after winlogo
i don't think that's it mate, i got a 24" monitor and a 50" tv running on my system
monitor on the gpu and tv on the intel cpu, so i can switch over when i'm in bed :)
try going into the bios and changing the setting on the onboard gpu from auto to pci-e it's some where in the settings, have a look
Hmmm i dont see that option. :-(
ok , i'm really not sure what it is then mate, if you can try installing the gpu in a different pci lane if that don't work, do you have a friend with a gaming pc try putting your card in his pc and try his/hers card in your pc....
EDIT: also is your bios up to date?
Have you disabled the integrated gpu in the motherboard bios? If not it could be that you've recently installed a software update (Windows Update) automatically unbeknown to you and it's not playing ball with your motherboards bios version.
I'd disable the integrated video if you haven't already and see how you get on. Also update your mobo's bios as Permafrost suggests :).
