SmoulderingCircuits
For those looking to pick up last gen bargains or want to keep their year old rigs up to speed with the latest, I thought it might be of use to you that I share these results for all my overclocking done over the past few days.
- The rest of the system is in my sig
- All overclocking was done in AMD Overdrive ONLY [CCC 11.6]
- Voltages were kept at stock
- Memory was kept at stock, ONLY core clock was adjusted
- All tests were carried out in Unigine Heaven 2.1 with the following settings: DX11, stereo 3D disabled, shaders high, tesselation normal, anisotropy 16x, AA 8x, 1600x900
- Before the final results were taken, a warm up benchmark was run first to ensure everything could attain maximum performance
- Fans at 90%
FPS are as follows:
850Mhz [Stock]
Min: 19.0
Avg: 55.6
Max: 110.9
860Mhz
Min: 17.7
Avg: 56.0
Max: 112.2
870Mhz
Min: 19.7
Avg: 57.5
Max: 114.4
875Mhz
Min: 30.8
Avg: 58.0
Max: 115.4
880Mhz
Min: 18.5
Avg: 57.8
Max: 115.5
885Mhz
Min: 30.8
Avg: 58.0
Max: 115.4
890Mhz
Min: 32.3
Avg: 58.1
Max: 116.0
895Mhz
Min: 27.8
Avg: 58.3
Max: 116.3
900Mhz
Min: 31.0
Avg: 58.2
Max: 115.5
Total gain
Min: + 12.0
Avg: + 2.6
Max: + 4.6
- Fans at 90%
FPS are as follows:
850Mhz [Stock]
Min: 19.0
Avg: 55.6
Max: 110.9
860Mhz
Min: 17.7
Avg: 56.0
Max: 112.2
870Mhz
Min: 19.7
Avg: 57.5
Max: 114.4
875Mhz
Min: 30.8
Avg: 58.0
Max: 115.4
880Mhz
Min: 18.5
Avg: 57.8
Max: 115.5
885Mhz
Min: 30.8
Avg: 58.0
Max: 115.4
890Mhz
Min: 32.3
Avg: 58.1
Max: 116.0
895Mhz
Min: 27.8
Avg: 58.3
Max: 116.3
900Mhz
Min: 31.0
Avg: 58.2
Max: 115.5
Total gain
Min: + 12.0
Avg: + 2.6
Max: + 4.6
