Firat
I would get the GTX680 only because it gives you options in the future, by getting 2 560Ti you would be "saturated" and would not be able to upgrade in the future, but with a 680 you can + its always best to invest in the newest as it is more efficient at what it does.
It may not be as good as 2 560ti's but i would recommend you to get the 680, rather than 2 560ti's as the upgrade path for them would end there.
there will come a day when you will need a better card for more demanding games, and it would be more feasible to add another gtx680 which will still be a good upgrade and cheaper then getting a new card entirely.
Hope that helps
Hope that helps
