4850 vs GTS 250
neoguyver1
Apologies it is a 450!!
My Asus 4850 matrix stopped working after a guy i knew tested it out luckily i was within the last month of my warranty and manged to get it sorted. The card that was returned was an MSI GTS450 1gb. I am contemplating giving it to a family member and I will get their Powercolor 4850 512mb + an akasa vortexx neo, which I can use in a rig i will throw together.
So my question is what is the performance gain they will get and has anyone had either of theses cards and seen the comparisons 1st hand?
I may be wrong, but I think that the 4850 will actually perform little bit better then the GTS 250. I will double check but I am fairly confident that it is better.
Apologies it is a 450 1gb.
4850 better, ive still got one. it was the time when they came out ati was teabagging nvidia, now its equal to a point
(amd fanboi)
