Reloaded2
Updatedwell done wiith the OC.
It's a shame you measure on overall and not graphics otherwise I would be in 12th place easy as I beat all the 480's and 1060's and one fury p. Oh well I'll have to upgrade my cpu
If that was the case then they would all be in separate catagories, I could argue the same as those lucky enough to have the 6950X trump the board (Cough Kaap) :lol: it's why all the important numbers are coloured. You've done well with the RX480 if I'm honest.It's a shame you measure on overall and not graphics otherwise I would be in 12th place easy as I beat all the 480's and 1060's and one fury p. Oh well I'll have to upgrade my cpu
What were the temps on the 480? Or were fans at 100% the whole time? Those numbers are pretty insane dude. Basically got a Fury X in gaming performance at half the TDP with those numbers
Temps sat around 82 degrees under the stress load. Nevertheless I wont put it on 1500mhz for the long term because the core voltage has to go up to 80 and I don't want it that high. My everyday clock is 1450mhz on core and 2150mhz on memory with a +50 power limit and +42 core voltage. I get an average of 75fps in witcher all on ultra and hairworks on medium.On that it averages around 72 degrees with that clock
What are exacally the average 480's graphics score anyways. Also aquatuning have sold out on my card now![]()
My Lord that's impressive for a 480 with that OC.
You're getting another? Damn hopefully you just get as lucky with it
Those XFX cards kick serious ass. Very impressive there man![]()
Ryzen won't bottleneck you with 2 cards. They are together not much more than a 1080. You'd be fine. You'd still get a large increase over a 2500k so it's not like you're losing anything, I'd just suggest waiting for Ryzen 5 though
http://www.3dmark.com/spy/1415734
AMD 1800X Stock 3.6GHZ
Sapphire Nitro Fury 1050 500
Sapphire Trix Fury 1040 500
Score 9304 GPU score 9510 CPU score 8288
GPU driver 17.3.2
15329, 1080ti sli @ 2025MHz, GPU score 20877, CPU score 6118, 7700k @ 5.2GHz, http://www.3dmark.com/spy/1417508
378.92
Kapp needs to put his 4 titan x and 6950x on the scoreboard
Does that mean this thread is dead then? Sorry for the mild necro bump, but I'm kinda bench horny today.![]()
