3dmark Time Spy DX 12 Bench.
oops.. seems my gpu oc reset due to driver update.. Il re run for the extra few points.
Re edit
ok so the GPU oc is worth ~300 points over all and nearly 400 on gfx or ~2-3fps. "STILL WORTH IT!"
http://www.3dmark.com/3dm/14373334?
3DMark Score
3148
Graphics Score
3289
CPU Score
2537
Graphics Test 1
21.49 fps
Graphics Test 2
18.82 fps
CPU Test
8.53 fps
Socre:
3148
Overclocks:
i5 2500k @ 4.333
gtx 780 @1358.7 Gpu / 1667.3 Vram "had to be tweaked with new driver releases since i did my sig"
base clock @101 (if i leave it at 100 it relly gives me 99. and 101 seems to really be 101 so its what i use)
ram @ 1612 Stock timings.
I guess it seems about right put me in the top bracket for similar systems "3rd if im to be precise, sop im happy with it as a 24/7 stable oc, i dont see the point in suicide test runs". Does show the benefit of newer hardware too if i compare to other scores here, although it does confirm my suspicions that a 480 or 1060 would not be worth the money for me.
oh and its the latest nvidia game ready drivers. 372.54
3dmark seems to call them 21.21.13.7254
agent_x007 3633, GPU Score : 3534, CPU Score : 4321
Core i7 3820 @ 5.0GHz, GTX 780 Ti @1208/1873 (max. Turbo) - LINK
Driver v368.81.
RX480
Core = 1450 Memory = 2150
CPU i5 2500k @4.5GHz with 2133 RAM
secure image upload
Graphics = 4646
CPU = 3246
Overall = 4363
That's the highest 480 here. My GPU is a beast though. On the latest crimson 17.3.1 which is why there is a warning.
EDIT: yes its the highest 480 here by a good 400 points. Its not letting me launch it online due to chrome being unresponsive.
New results. Finally beat all the 1060's and 480 in graphics. The CPU test is a let down though which will drag me down the scoreboard. I will upgrade to an i7 7700k soon
Graphics = 4755
CPU = 3241
Overall = 4443
RX480 XFX Black Edition
Core = 1475 Memory = 2250
CPU i5 2500k @4.5GHz with 1866 RAM
upload photograph
Same problem. I cant go online it says google chrome is unresponsive.
Graphics = 4755
CPU = 3241
Overall = 4443
upload photograph
I7?! Boo! Ryzen! Lol
That's some serious scores. What GPU is that?
I can update the OP that's no problem, only issue is I need your timespy result web link and a valid result.
RX 480. You should know NBD we did a whole thread on the XFX Black edition 480 - it's a beast. I got 1475mhz on core and 2250mhz on memory. It's definitely the best 480 or 1060 here for graphics - CPU is another story :) What do you think. I know you have the MSI 480 too - what are your scores like. I'll also update my original thread on the XFX 480
In terms of ryzen I'm just not sure yet. I think it's too early to adopt
The validation warning is only the driver and that happens with all new drivers but I can't get timespy demo to launch Google chrome
What I might try to do is OC my cpu to 4.6GHz and push my 480 to 1485 on the core and 2250 on the memory which is already maxed just to get higher scores and get the link going. Great thing is this GPU isn't pushing past 2.5v on timespy so I have a some headroom
I thought you returned it because of faulty something.. couldn't remember, that's why I asked
I think those are insane numbers. Haven't seen anyone else hit those clocks
Yea it turns out the fans were faulty. They sent me new Red LED ones and its been perfect. I'm surprised no one else can hit those numbers or clocks. Im gonna go balls out and max memory and go 1490 on the core and OC my cpu to 4.6 GHZ. Lets see what happens
FINAL RESULTS
http://www.3dmark.com/3dm/18675936?
Core: 1500 MHz
Memory: 2250
CPU: i5 2500k @ 4.6GHz
Graphics: 4816
CPU: 3253
Overall: 4492
add photos online
I hit 1500Mhz on core and 2250MHz on memory - These are insane numbers for the 480. The stock is 1266
Here is the card in action - How about that NeverBackDown ;)
All I need now is a new CPU
