3DMark 2005 Scores: Show It Off!
Here ya go girlies. My latest score on the single 7800GTX clocked at 626/1830
10869 is aight...mefinks I should go for breaking the 11k barrier :)
3DMark Score
(3DMarks)
10869
CPU Score
(CPUMarks)
7615
http://service.futuremark.com/compare?3dm05=1617326
Well here is mine, Should i be happy or sad:
My XFX 7800GT Xtreme Edition 256MB is at the stock settings of 450mhz core and 1.05ghz memory.
Sam:D
name='kempez815' said:
Yeah thats a pretty decent score mate :)
Its nice to get a good result, I am having trouble overclocking this XFX 7800GT as they come at 450mhz core and if i go any higher than 465mhz and click test changes it reports back unstable. Should this report be ignored and try a 3dmark test to see what the stableness is like or should i listen to what it tells me as i have never overclocked a nvidia card before.
Thanks, Sam
Use Riva Tuner and disable the "internal clock test".
Your card shouold make it a bit further :)
Use RTHRIBL to test stability, as well as ATI tools :)
Here's what my setup pulls w/ my Opty @ 2.9 and vid cards at 450/1150. I volt modded the BIOS's on both of my vid cards again and they seem to be running peachy, better than the last time I vmodded em thats for sure. I don't think I've been able to run 450mhz stable on these eVGA's before, but they worked out nicely this time, I'm even thinking about trying to bump em up a bit higher as I was getting no artifacting at all.
So you did break down and get yourself a x1900 :p Did you actually get an XTX (I know you say such a waste, so I doubt that), flash an XT to an XTX, or did it just recognize as an XTX cause of the high clock? Nice anyway:D
not yet. The core is at 702 mhz and memory at 795 mhz. I might get some ramsinks to see whether I can go higher. The core sure as hell prolly has some more in it. It barely goes over 40C after 4 hours of bf2.
@ WC. - It is an 1900xt. Not an xtx . For some reason it shows up as xtx on 3dmark. Ohh well . Still learning how to oc the radeon cards. The image quality in the driver was set to quality. So I can still prolly go higher. Lets see how I can do.
