3DMark 2003 Scores: Show It Off!
Ionicle I'd reccomend picking up a new PSU with that DFI LanParty.
Here are the two PSU's that would fit you well for now & the future.
You pick the one, doesn't really matter--but I stand behind Enermax all the way. I have my Enermax powering my system perfectly. My dad has a True Power 430w powering his system perfectly, too. (Though he doesn't have as power-demanding equipment.)
They are both ATX 2.0, and have the 24 Pin ATX power cable. They also both have a 6-Pin PCI-Express video card power connector for a future upgrade.
Antec TRUEPOWERII TPII-430 430W Power Supply - Retail - $65
ENERMAX EG425P-VE SFMA 2.0 420W Power Supply - Retail - $77
Yes, the Enermax is quite alot more, but you definentally get what you pay for in a Power Supply. The Enermax has a lot of neat features like an EMI Ring Core; which 'dramatically' reduces Electromatic Interference given off by the PSU.
It also features a 'smart fan' which lets you control the fan's, within it's own threshold so you cannot overheat the PSU purposly, for any amuzement purposes :rollingla . The 'smart fan' also keeps the PSU fan's on AFTER you shut the pc off, until the air in teh case is below 40ºC! :cool:
Good luck man, and happy PSU shopping.
name='ionicle' said:
i live in the U.K...
I'll offer you an Antec NeoPower at the end of the month for £60 + P&P. It has all blue UV cables (braided) and is ATX 2.0 compatible and is modular and looks sweet.
I'm getting a PCP&C for £160 (ouch :() :)
cant aford it stil payin off daveo's card! i stil have £45 to pay off! thats 5 weeks, then 6 weeks to get £60:( so thaks but no thanks i will have to go back to a old spare of mine thats 250W i nabed it outa an old windows 98 comp that i took to pieces to salvage the componants
i think.....*rumages*.....thats my only spare.....
that psu of yours kempez sounds :yumyum: but i cant aford it! i cant aford nethin atm
Hey FragTek, just made an observation, your graphics card wasn't running at stock core speeds like you thought it was. Take a look:
Fill Rate (Multi-Texturing) 6990.4 MTexels/s
I know that at 425MHz the max theoretical fill rate is 6800 MTexels/s.
Your max theoretical must have been over 7000 MTexels/s which means your card was running fully overclocked, thought I'd clear up ORB's mystery mistake ;)
i just redid the 3dmarks 03 with my g/card oc'ed and i got:
how could you get that on a 9800pro.... i only just scrap past that on a 9800xt which has double clock speeds and mine is overclocked like a mofo and yours isnt?
lol @ lucky. harmonicgen007 are you using the latest drivers?? if not downlaod them from ati's website. and before you install use driver cleaner in safe mode to remove any trace of drivers ;)
