dukeReinhardt
cooler: phanteks ph-tc14pe
case: fractal arc midi
2 phanteks 140mm fans in front, 3 fractal 140mm fans in back exhaust, 2 ty-140s on the cooler.
there's nothing even in the case at the moment except for one tiny graphics card, and the hdd cage has been removed. fans are at between 80 to 100%. i kind of thought temps would be fantastic but idle 1600mhz 0.976v (everything auto in bios, this is lowest things get by themselves) 3570k is about 31 degrees, and my room is cooold. people on stock cooling with worse case cooling than me are getting <30. one thing to note is that the coolest core is about 18 degrees, while the hottest is 31. what's up with that
is this all normal?
thanks
is this all normal?
thanks
