dhoom New member Nov 22, 2013 #1 How do i set up 3 Way SLI on my ASUS Maximus VI Formula ? Between PCIe_1 and PCIe_2 there is 6 cm. Between PCIe_2 and PCIe_3 there is 4 cm. From PCIe_1 to PCIe_3 there is 10 cm. How am suppose to do that ? I still want it to look good!! Last edited: Nov 22, 2013
maniac New member Nov 22, 2013 #2 just use two single flexible sli bridges from the 1st card to the 2nd, and from the 2nd to 3rd card.
T theDTP New member Nov 22, 2013 #3 maniac said: just use two single flexible sli bridges from the 1st card to the 2nd, and from the 2nd to 3rd card. Click to expand... ^ this, from 1 to 2 and from 2 to 3. If you want it to look good, then cut a piece of plexi or aluminium to the total length and width of the 2 bridges and use some double sided tape
N netwalker New member Nov 24, 2013 #4 dhoom said: How do i set up 3 Way SLI on my ASUS Maximus VI Formula ? Between PCIe_1 and PCIe_2 there is 6 cm. Between PCIe_2 and PCIe_3 there is 4 cm. From PCIe_1 to PCIe_3 there is 10 cm. How am suppose to do that ? I still want it to look good!! Click to expand... You do not need to worry because this board is only 2 way Sli compatible. It is however 3 way XR compatible tho. Cheers...
