3.4 - 3.6
Youngie1337
Hello people :wavey:
I was just wondering since I lost some information in which Moogle aka Google sent me about getting the Q6600 @ 3.6.
Could someone please tell me what needs to be 'upped' for me to achieve 3.6 or 3.8.
My current settings:
AI Overclock Tuner: Manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: 333
FSB Frequency: 378
PCI-E Frequency: 100
DRAM Frequency: DDR2-800MHz (It'll be higher this time so try a lower divider. You might have to choose 754MHz DDR2 but make sure to choose anything lower than your current ram speeds. If you can't choose a decent ram speed then change FSB Strap to North Bridge to Auto)
DRAM Timing Control: Manual
1st Information
CAS# Latency: 4
DRAM RAS# to CAS# Delay: 4
DRAM RAS# Precharge: 4
DRAM RAS# Activate to Precharge: 12
3rd Information
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
AI Clock Twister: Auto
AI Transaction Booster: Auto
CPU Voltage: 1.40000
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.32
DRAM Voltage: 2.1
NB Voltage: 1.32
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Margin Enhancement: Optimized
Advance CPU Settings
C1E Suppport: Disabled
CPU TM Function: Enabled
Intel SpeedStep Tech: Disabled
Thank you:).
name='Ham' said:
NB strap to 400 might help. As may a bit more NB voltage.
Alright thank you, I'll have a look.
EDIT: No change, although I did up the FSB +2 and got to 3.45 LOL. Don't wonna up it too much unless this is the only way for 3.6-3.8.
I got the impression from your last post that you're not sure what increasing the FSB equates to in terms of an overall clockspeed.
CPU Clock Speed = CPU FSB * CPU Multi
The Q6600's multi is 9x
~2400MHz = 266MHz * 9
So 3600MHz = 400MHz * 9
and 3800MHz = 423MHz * 9
As mentioned, from 3600MHz and up, set a CPU to NB Strap of 400MHz and work your way up from there. Be ware that your memory frequency will effectively be overclocked from this point onwards and could limit you.
God we have Einstein... :D
Cheers mate.
UPDATE: I changed FSB to 400 and it failed to boot. Lowered it bit by bit and was only stable @ 3.4. Any way of getting it to boot? Perhaps I should up the voltage to CPU?
Make sure that your RAM is running 1:1 with your CPU's FSB. At 400FSB, the option for DDR2-800 should be selected. Try another 0.0125V on the CPU and maybe one notch up on the MCH Voltage.
Didn't work :(. Just loads up Windows onto Vista LOGO and BSOD.
And I will try Nepas.
Is that an improvement over what happened without voltage increases? If so, perhaps another bump on the MCH may help?
Still nothing :(, failed to even post, settings then reverted to default.
to get my chip to 3.6 i needed just over 1.52v you will probz need around the same it was only the newer GO's that got to 3.6 with less
what cooler are you using? Before you up your voltage any more you need to make sure you can get rid of the increased heat....
If your heatsink is good enough then keep increasing voltage in the smallest incerement possible till u can boot or until u get to around 1.5v
name='°TheMadDutchDude°' said:
As you're trying for 3.6. Increase your volts to 1.45 and work your way back from there.
Alright thanks I'll try that.
Noctua NP.
http://www.tweak.dk/review/Noctua_NH-U12P_UK/713/1/2
