Cursed Reality
Hello,
Thinking about upgrading my current PC (taking parts from old build and buying the ones listed below), and I have thought about these parts for awhile now, but I wanted some different perspectives.
*I like being up to date and on the bleeding edge.
Some info, this rig is for gaming / streaming 1080p, and I run 3x 27in monitors. Sometimes I play on 1, sometimes I play on 3. (Depending on game)
I am going to OC my CPU / GPU to stable clocks.
If you have any suggestions or thoughts about the build, drop a post.
*Money is not an issue.
Thanks.
CPU: Intel - Core i7-4770K (Haswell)
Motherboard: Asus Maximus VI Extreme (Haswell)
Memory: Dominator Platinum 16GB DDR3 1866MHz CL9 Quad Channel Kit (4 x 4GB)
Storage(Already Present): 1x Intel 520 SSD - 120gb / 2x Caviar Black - 2TB
Video Card: EVGA - GTX Titan or EVGA - GTX 780
Case : Cooler Master - Cosmos II
Power Supply(Already Present): Corsair - AX1200
Liquid Cooling Option:
________________________________________________
Water Block:Apogee HD
Pump: MCP655-B
Radiator: MCRx20-QP "Quiet Power" Radiator Series (Triple 120mm)
Reservoir: FrozenQPCMods Liquid Fusion Blue Helix Reservoirs Polycarbonate Tubing 250MM
Fans :
Air Series SP120 High Performance Edition High Static Pressure 120mm (Radiator Fans)
Air Series AF120 Performance Edition High Airflow 120mm (Case Fans)
This is going to be my first "liquid cooled build" so any suggestions in regards to that would also be appreciated.
Looking forward to your answers .
Thanks.
Pump: MCP655-B
Fans :
