27 inch overkill?
Wazza
Would a 27 inch monitor be overkill for desk use whether it be 1080 or 1440?
I'll probably wall mount my next monitor so it'll be a couple of inches further away...
I have a fair bit of grunt to push a monitor a long nicely with a 4790k and gtx 970.
So is a 24 inch 1440p a possibility?
27'' isn't overkill imo, but I wouldn't recommend a 1080p 27'' as the pixel density isn't that high.
I'm not aware of any 24'' 1440p displays but the Dell U2515H is an option if you don't want 27''
Also depends on the size of said desk? How far you sit from the panel? How long you stare at it?
1080p = upto 24".
1440p = 27" or greater.
(PPI sweet spots)
