yassarikhan786 New member Jan 27, 2012 #21 Are you using xmp? If so, just set the frequency and timings manually and you should be good.
S_I_N New member Jan 27, 2012 #22 Big Boss said: and vcore shows 1.344 normal 1.35 on load but when i validate it goes to 1.368 Click to expand... thats totally normal bro so ur oc is actually 4.6GHz at 1.368 vcore thats what the board has determined it needed to stabilize ur oc with the parameters you set in bios.
B Big-Boss New member Jan 27, 2012 #23 Thanks Yass I enabled xmp profile and its what it supposed to be also i lowerd my vcore by .5 and is still working i set it to 1.34 il try 1.32 now and see what it does
B Big-Boss New member Jan 27, 2012 #24 done guys working set temp to 1.32 below are screen Normal without prime 95(max temp says 70+ is that bad or good) Uploaded with ImageShack.us on Load Uploaded with ImageShack.us cpuz sees vcore as 1.344
yassarikhan786 New member Jan 27, 2012 #25 Those are some awesome temperatures mate. How long did you run the test to see those temps?
B Big-Boss New member Jan 27, 2012 #26 ii crashed on me after 10 mins bsod just set it to 1.33 see how long it lasts if not il stick with 1.34
B Big-Boss New member Jan 27, 2012 #28 no i think il stick with 1.34 at 1.33 pc shut down after 30 mins dont know if that was something else or not but 1.34 vcore it is
