Jeronbernal
250Dee Corsair 250D Build Log
Intro:
Hey all, i'm starting a new build now that my 760T Entry to the Corsair PC Domination contest is close to done, and am just waiting for aesthetic acrylic pieces.
I'm new to posting builds, but for those that are curious, here's a link to my PC Domination Entry, OCN Worklog, and OC3D Rig Post
PC Domination Link
OCN Lucky Seven Build Log
OC3D Rig Post
Plans:
-My plans for this build are to watercool everything possibly feasible in the case, there are 3 stock radiator mounting spots in the case, 2x 80mm, 1x 120/140/180/200, 1x240
-Due to size restrictions, i will be using acrylic tubing due to the fact it will be easier to route the tubing, than to use normal flexible tubing
-There is a vent for intake/exhaust where the video card will be, but since i will not be using it, i will be turning that area into a plexiglass window
-The front of the 250D is like most corsair obsidian cases, where the front panel covers the fans intake, so i will be removing the center area of the front panel, and creating a grill
-Also due to limited spacing, the wiring will also need to be shortened aswell, i will be using one of the smaller available Corsair PSU's that i have at my disposable, which is a AX860
-If room allows, i will be adding a vertical slim slot load drive through the top of the case
Parts List:
Components:
CPU:Intel i7 4770K
MOBO:ASUS Maximus VI Impact
GPU:EVGA 780ti Reference
RAM:Corsair Vengeance Pro (I would have used dominator platinum's, but learning from my last build, the heatspreaders are not removable)
PSU:Corsair AX860
SSD:256GB Samsung PRO 840
HDD:1TB Western Digital Black
Cooling:
EK-FB ASUS M6I - Nickel (Original CSQ)
EK-RAM Monarch X2 - Nickel (Original CSQ)
EK-DDC X-RES 100 CSQ - Acetal
EK-FC780 GTX Ti - Nickel (Original CSQ)
Alphacool NexXos UT60 120 (120mmx1)
Alphacool NexXos ST30 240 (120mmx2)
Alphacool NexXos XT45 160 (80mmx2)
Bitspower C47 Matte Black Fittings
Bitspower Ball Valve
Bitspower 45/90 Degree Adapters
E22 Extruded Acrylic Tubing 10mm/12mm
Other Parts:
1.77" Acrylic 18"x18" Smoke, Clear, Black, and Translucent sheets
Modders Mesh Undecided Style
*All parts are subject to change
Thanks everybody, and i hope this build will be as fun as the last, and i hope everyone along for the ride enjoys
Here's some pic's so far, just some unboxing with phone pics
Intro:
PC Domination Link
OC3D Rig Post
Plans:
Parts List:
Components:
CPU:Intel i7 4770K
PSU:Corsair AX860
Cooling:
Other Parts:
