22" 226BW Samsung or 24" Acer?
kerochi
Help I cant decide between the two.
I really want to make the most of my 8800GTX pushing at 1920x1200 res, so a 24" would be ideal.
Acer is only a couple hundred more expensive than the Samsung, so it seem worth the price.
The Samsung 226BW seems pretty solid and reliable and has a really fast response time, but is only 22" in size.
I've read that the Acer has many issues with overheating and showing a very annoying "no signal" display.
So I dont know if I should make the jump or not to go for the large and slightly unreliable Acer or the small very reliable Samsung.
I am mean I wouldn't mind getting the 22", but would I be wasting the potential of my GPU? OR is the 22" absolutely fine and gives me plenty of room to max out all the GPU settings compared to a 24"?
http://www.newegg.com/Product/Product.asp?Item=N82E16824009089
https://www.komplett.co.uk/k/ki.asp?sku=331034&view=detailed
I just got a 20" and love it. I have had problems in the past with Acer Products/Service so I would definitely go with the Samsung.
If i do get a 24", i can only afford the acer.
But i've read loads of reviews that ppl had to send them bk just after a couple of weeks... so this is where i'm stuck
The Acer 24" looks pretty good. I'd go for that one out of those two.
Because the res is better and it is a P-MVA panel, the 22" will be a TN
